Delta Plot Post Processing
Compare the difference between run and reference data.
View Delta Plot
Compare differences between input variable and output response run and reference data in a bar chart format from the Delta Plot post processing tab.
  1. From the Post Processing step, click the Delta Plot tab.
  2. Using the Channel selector, select the channels to display in the plot.
  3. Analyze the plot.
