Delta Summary Post Processing
View the difference between run and reference data.
View Delta Data Summary
View a detailed summary of the differences between input variable and output response run and reference data in a tabular format from the Delta Summary post processing tab.
  1. From the Post Processing step, click the Delta Summary tab.
  2. Using the Channel selector, select the channels to display in the delta summary table.
  3. Analyze the summary.
