Delta Scatter Post Processing
Visualize the difference between run and reference data.
View Delta Scatter
Visualize the differences between input variable and output response run and reference data in a scatter plot format from the Delta Scatter post processing tab.
This can be very useful to visualize the trade-off front after a multi-objective optimization.
  1. From the Post Processing step, click the Delta Scatter tab.
  2. Using the Channel selector, select the channels to display in the plot.
  3. Analyze the scatter plot.
