Cosine Tire Graphics Tab
The Cosine Tire Graphics tab appears when an F-Tire property file is chosen. It defines the cosin tire’s graphic properties. A check box is available to produce and visualize the deformable tire graphics. The tire graphics are rendered by HyperView based on the node locations provided by Cosin.
Figure 1. Cosine Tire Graphics Tab
Reference Frame | The frame of reference for the graphics. Options are: Rim-Fixed Frame, Inertial Frame and Tydex C Frame. Default = Rim-Fixed Frame. This option renders the graphic in tire force reference marker. |
Circumferential Sections | Number of divisions along the circumference. |
Lateral Sections | Number of divisions along the tire width. |
Left Extreme | Beginning point of graphics on left side of tire. 0 indicates left rim flange. |
Right Extreme | Ending point of graphics on right side of tire. 1 indicates right rim flange. |
