The AutoDamper entity is a force-velocity model designed to easily simulate a shock absorber used in ground vehicles.
The AutoDamper entity reads force-velocity data from a file written in the TeimOrbit format.
MotionView and MotionSolve support multiple tire models. The AutoTire auto entity can be added to a full vehicle model as a single entity or
as a pair.
as a pair.
The SoftSoil Tire Graphics tab appears when a SoftSoil Tire
and corresponding SoftSoil Road property files are chosen. It provides the options to create
an animated SoftSoil graphics in HyperView. A check box is
provided to activate the graphics. A graphics system collector is available to choose the soil
graphics system, this soil system is created when generating the road using the road tools
(see Visualization - Road Tools). This will be used to create a
moving carpet type of graphics to show the SoftSoil deformation as the vehicle moves over it.
Figure 1. SoftSoil Tire Graphics Tab
When there are multiple AutoTires in a model, it is recommended to:
Use a single Graphic System in all of them.
Select/Clear the Animated Graphics option in all of them.
All the graphics that are created use the MotionSolve Grasub internally for animation in HyperView.
