Limitations
- The unit’s information is not picked up from the .pwr file. Currently the torque must be in Nm, the engine speed in RPM, and the throttle between 0 and 1.
 - On Engine stall, the simulation will terminate.
 - It is recommended that the you set the initial engine speed such that it is matched to the driven wheel speeds considering the gear ratio. This will avoid transients.
 - The reaction torques that the engine and clutch produce that are transmitted to the vehicle chassis are currently not computed and applied to the engine body.
