Event Specific Reports
Various plots are reported in different vehicle events. The plots are selected based on metrics that are important for a given event.
The Reports can be accessed from the browser context menu on each event or you can also use the menu item .
The following topics list the plots, page-wise, for each event:
Constant Radius Event
- Steering Input and Accelerations
- Steering Wheel Angle vs. Time
 - Steering Wheel Torque vs. Time
 - Lateral Acceleration vs. Time
 - Longitudinal Acceleration vs. Time
 - Vehicle Velocities
- Yaw Rate vs. Time
 - Longitudinal Velocity vs. Time
 - Lateral Velocity vs. Time
 - Vehicle Slip Angles
- Front Sideslip Angle vs. Time
 - Rear Sideslip Angle vs. Time
 - CG Sideslip Angle vs. Time
 - Roll Angle
- Roll Angle vs. Time
 - Steer/Suspension Travel
- Front Steer Angle vs. Time
 - Rear Steer Angle vs. Time
 - Front Suspension Travel-left vs. Time
 - Front Suspension Travel-right vs. Time
 - Rear Suspension Travel-left vs. Time
 - Rear Suspension Travel-right vs. Time
 - Steering, roll and torque
- Steering Wheel Angle vs. Lateral Acceleration
 - Steering Wheel Torque vs. Lateral Acceleration
 - Roll Angle vs. Lateral Acceleration
 - Vehicle Path
 - Vehicle Slip vs. Acceleration
- Front Axle Sideslip vs. Lateral Acceleration
 - Rear Axle Sideslip vs. Lateral Acceleration
 - CG Sideslip Angle vs. Lateral Acceleration
 - Steering Wheel Angle vs. Vehicle Sideslip Angle
 - Tire Lateral Slip
- Left Front Tire Lateral Slip vs. Time
 - Right Front Tire Lateral Slip vs. Time
 - Left Rear Tire Lateral Slip vs. Time
 - Right Rear Tire Lateral Slip vs. Time
 - Vertical Tire Forces
- Left Front Tire Vertical Force vs. Time
 - Right Front Tire Vertical Force vs. Time
 - Left Rear Tire Vertical Force vs. Time
 - Right Rear Tire Vertical Force vs. Time
 - Lateral Tire Forces
- Left Front Tire Lateral Force vs. Time
 - Right Front Tire Lateral Force vs. Time
 - Left Rear Tire Lateral Force vs. Time
 - Right Rear Tire Lateral Force vs. Time
 - Longitudinal Tire Forces
- Left Front Tire Longitudinal Force vs. Time
 - Right Front Tire Longitudinal Force vs. Time
 - Left Rear Tire Longitudinal Force vs. Time
 - Right Rear Tire Longitudinal Force vs. Time
 - Wheel Aligning Torques
- Left Front Tire Aligning Torque vs. Time
 - Right Front Tire Aligning Torque vs. Time
 - Left Rear Tire Aligning Torque vs. Time
 - Right Rear Tire Aligning Torque vs. Time
 - Vertical Tire Forces vs. Lateral Acceleration
- Left Front Tire Vertical Force vs. Lateral Acceleration
 - Right Front Tire Vertical Force vs. Lateral Acceleration
 - Left Rear Tire Vertical Force vs. Lateral Acceleration
 - Right Rear Tire Vertical Force vs. Lateral Acceleration
 - Lateral Load Transfer
- Front Lateral Load Transfer vs. Lateral Acceleration
 - Rear Lateral Load Transfer vs. Lateral Acceleration
Single Lane Change Event
- Yaw Rate vs. Time
 - Roll Angle
 - Vehicle CG Displacement
- Vehicle CG Disp(Y) vs. Vehicle CG Disp(X)
Double Lane Change Event
- Yaw Rate vs. Time
 - Roll Angle
Swept Sine Event
- Swept Sine: SWA, Lateral Acceleration, Yaw Rate, Roll
 - Yaw Rate vs. Time
 - Frequency Plots, Magnitude and Phase
- Ay/Steering Wheel Angle Magnitude
 - Ay/Steering Wheel Angle Phase
- Yaw Rate/Steering Wheel Angle Magnitude
 - Yaw Rate/Steering Wheel Angle Phase
- Roll/Ay Magnitude
 - Roll/Ay Phase
Straight Line Acceleration Event
 - Tire Longitudinal Slip
- Left Front Tire Longitudinal Slip vs. Time
 - Right Front Tire Longitudinal Slip vs. Time
 - Left Rear Tire Longitudinal Slip vs. Time
 - Right Rear Tire Longitudinal Slip vs. Time
 - Vertical Longitudinal Acceleration and Velocity
 - Suspension Travel
 - Steering Wheel Angle and Torque
 - Drive Torque vs. Time
 - Pitch, Front Lift and Rear Squat
- Pitch vs. Longitudinal Acceleration
 - Front Lift vs. Longitudinal Acceleration
 - Rear Squat vs. Longitudinal Acceleration
 - Vehicle Tire Forces
- Left Front Tire Vertical Force vs. Longitudinal Acceleration
 - Right Front Tire Vertical Force vs. Longitudinal Acceleration
 - Left Rear Tire Vertical Force vs. Longitudinal Acceleration
 - Right Rear Tire Vertical Force vs. Longitudinal Acceleration
 - Axle Loads
- Front Axle Load vs. Longitudinal Acceleration
 - Rear Axle Load vs. Longitudinal Acceleration
- Left Load Transfer vs. Longitudinal Acceleration
 - Right Load Transfer vs. Longitudinal Acceleration
Straight Line Braking Event
 - Vertical Longitudinal Deceleration and Velocity
- Longitudinal Deceleration vs. Time
 - Suspension Travel
 - Brake Torque
- Left Front Brake Torque vs. Time
 - Right Front Brake Torque vs. Time
 - Left Rear Brake Torque vs. Time
 - Right Rear Brake Torque vs. Time
 - Pitch, Front Drive and Rear Lift
- Pitch vs. Longitudinal Deceleration
 - Front Drive vs. Vehicle Deceleration
 - Rear Lift vs. Vehicle Deceleration
- Left Front Tire Vertical Force vs. Vehicle Deceleration
 - Right Front Tire Vertical Force vs. Vehicle Deceleration
 - Left Rear Tire Vertical Force vs. Vehicle Deceleration
 - Right Rear Tire Vertical Force vs. Vehicle Deceleration
 - Axle Loads
- Front Axle Load vs. Vehicle Deceleration
 - Rear Axle Load vs. Vehicle Deceleration
 -  Longitudinal Load Transfer
- Left Load Transfer vs. Longitudinal Deceleration
 - Right Load Transfer vs. Longitudinal Deceleration
Sinusoidal Steering Event
- Yaw Rate vs. Time
 - Vehicle CG Displacement vs. Time
Brake In Turn Event
 - Axle Loads
- Front Axle Load vs. Lateral Acceleration
 - Rear Axle Load vs. Lateral Acceleration
- Front Load Transfer vs. Lateral Acceleration
 - Rear Load Transfer vs. Lateral Acceleration
J Turn Event
- Tire Lateral Slip
 - Axle Loads
 - Steering, Roll and Torque
 - Yaw Rate vs. Lateral Acceleration
 - Sideslip
 - CG Sideslip Angle
 - Understeer vs. Lateral Acceleration
Throttle-off Cornering Event
- Yaw Rate vs. Time
Swept Steer Event
- Yaw Rate vs. Time
 - Roll Angle
 - Vehicle Path
 - Tire Lateral Slip
Pulse Steer Event
- Yaw Rate and Vehicle CG Displacement
- Yaw Rate vs. Time
 - Steering Input
Throttle-off Turn-in Event
- Tire Lateral Slip
 - Axle Loads
 - Engine Torque vs. Time
Step Steer Event
 - Yaw Rate vs. Time
 - Steering Wheel, Torque and Roll
Power Off in a Straight Line Event
 - Axle Loads
 - Front Drive vs. Longitudinal Acceleration
 - Rear Lift vs. Longitudinal Acceleration
n-Post Shaker Event
- Signal Type = Acceleration/Displacement
- Animation of the Event
 - Vehicle Body Accelerations
 - Steering Wheel Accelerations
 - Wheel Restraint Forces (as many pages as the number of wheels)
 - Actuator Displacements (as many pages as the number of actuators)
 - Actuator Forces X/Y/Z (as many pages as the number of actuators)
 - Signal Type = Force/Moments
 - Actuator Force/Moments
Stability Analysis
- Analysis Mode = Linear
 - Eigenvalues reported by MotionSolve for the model (.eig file)
 - Analysis Mode = Apply Pulse/Apply Disturbance
 - Applied Pulse or Disturbance
- Force Magnitude
 - Torque Magnitude
- Steer Angle vs Time
 - FFT Magnitude of Steer Angle
 - Vehicle Displacements
- Roll Angle vs Time
 - FFT Magnitude of Roll Angle
 - Yaw Angle vs Time
 - FFT Magnitude of Yaw Angle
