OS-V: 0060 Thick Plate Pressure
Test No. LE10 The model is a thick plate subjected to uniform normal pressure of 1MPa on the upper surface of the plate. OptiStruct examines the direct stress at the point D for linear static analysis.
図 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
Second order Hexahedral, Penta and Tetra elements are used to create the coarse and fine mesh. A uniform pressure of 1 MPa is applied on the upper surface of the plate.
- Material Properties
- Value
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
Linear Static Analysis Results
| Direct Stress at Point D (MPa) | Normalized with the Target Value | |
| Solid Hexahedral: | ||
| Hex20 coarse | 5.32 | 1.011278195 |
| Hex20 fine | 5.58 | 0.964157706 |
| Solid Wedges: | ||
| Penta15 coarse | 5.9484.91 | 1.10557620895723014 |
| Penta15 fine | 5.94 | 0.905723906 |
| Solid Tetrahedral: | ||
| Tetra10 coarse | 5.741 | 0.937118969 |
| Tetra10 fine | 5.029 | 1.069795188 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
- LE10Hex20C.fem
- LE10Hex20F.fem
- LE10Pyr15C.fem
- LE10Pyr15F.fem
- LE10Tet10C.fem
- LE10Tet10F.fem
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
