OS-V: 0070 Solid Cylinder/Taper/Sphere - Temperature
Test No. LE11 The model is a thick solid cylinder subjected to linear temperature gradient in the radial and axial direction. OptiStruct examines the direct stress at the point A inside the cylinder on the y axis for linear static analysis.
図 1. FE Model with Boundary Conditions and Loadcases
Benchmark Model
Second order Hexahedral, Penta and Tetra elements are used to create the coarse and fine mesh. A Linear temperature gradient of T°C = (x2 + y2)1/2 + z is applied in the radial and axial direction from the center of the cylinder. Only one quarter of the cylinder is considered.
- MAT1 Isotropic
- Young's Modulus
- 210 x 103 MPa
- Poisson's Ratio
- 0.3
- Coefficient of Thermal Expansion
- 2.3 x 10-4/°C
Linear Static Analysis Results
Direct Stress at Point A (MPa) | Normalized with the Target Value | |
Solid Hexahedral: | ||
Hex20 coarse | -93.21 | 1.126488574 |
Hex20 fine | -99.12 | 1.059322034 |
Solid Wedges: | ||
Penta15 coarse | -100.3 | 1.046859422 |
Penta15 fine | -103.7 | 1.012536162 |
Solid Tetrahedral: | ||
Tetra10 coarse | -91.97 | 1.141676634 |
Tetra10 fine | -98.68 | 1.064045399 |
Model Files
必要なモデルファイルのダウンロードについては、モデルファイルへのアクセスを参照してください。
- LE11Hex20C.fem
- LE11Hex20F.fem
- LE11Pyr15C.fem
- LE11Pyr15F.fem
- LE11Tet10C.fem
- LE11Tet10F.fem
Reference
NAFEMS R0015 - Selected benchmarks for natural frequency analysis
