In a Cartesian coordinates system, the coordinates of a material point in a reference or
initial configuration are denoted by
. The coordinates of the same point in the deformed or final
The motion or deformation of a body can thus be described by a function
where the material coordinates
and the time
are considered as independent variables:
(1)
The function
gives the spatial positions of material points as a function of time.
The displacement of a material point is the difference between its original and final
positions:
(2)
It is possible to consider displacements and, as a consequence final coordinates
, as functions of initial coordinates
. The initial configuration is assumed to be perfectly known and
each coordinate
identifies a specific material point. For this reason, the initial
coordinates are called material coordinates.
On the other hand, the final coordinates
identify a point of space which can be occupied by different
material points according to the different analyzed configurations. For these reasons, the
is called spatial coordinates.
In solid mechanics, material coordinates are usually called Lagrangian
coordinates. In their general definition, they are given by the values of the
integration constants of the differential equations of particle trajectories. A particular
definition consists in using the coordinates
of the particle in the initial configuration. This point of view
corresponds to the definition of material coordinates in solid mechanics.
Use of material coordinates is well suited for solid mechanics as we seek to analyze the
evolution of a set of points for which we search the final configuration and properties.
Integration can be performed in the initial configuration for which geometric properties are
usually simple.
In fluid mechanics however, the engineer is more interested in the evolution of a situation in
a region defined by fixed boundaries in space. Boundaries are eventually crossed by fluid
particles. It is the spatial configuration which is important while the set of particles may
vary. This is the reason why fluid mechanics is usually developed using spatial or Eulerian
coordinates.
In solid mechanics, the Eulerian formulation consists in considering displacements and initial
coordinates as function of spatial coordinates
. A problem for using Eulerian coordinates in solids mechanics is
the difficulty of formulating constitutive equations, such as the relationship between stresses
and strains that can take into account change of orientation. For this reason solid mechanics
are principally developed using the Lagrangian point of view.
The reason for using the Lagrangian form for solids is primarily due to the need for accurate
boundary modeling.
