Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of
nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box.
The purpose of this manual is to describe the numerical methods included in Radioss.
Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree
of freedom (DOF), and there can only be one constraint per DOF.
The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered
to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability
can be applied to a variety of computational problems.
A large variety of materials is used in the structural components and must be modeled in stress analysis problems.
For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the
behavior of the material.
Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel
version SMP made possible the exploration of shared memory on processors.
Kinematics deals with position in space as a function of time and is often referred to as the
"geometry of motion". 1 The motion of particles may be described through the
specification of both linear and angular coordinates and their time derivatives. Particle motion
on straight lines is termed rectilinear motion, whereas motion on curved paths is
called curvilinear motion. Although the rectilinear motion of particles and rigid
bodies is well-known and used by engineers, the space curvilinear motion needs some feed-back,
which is described in the following section.
Space Curvelinear Motion
The motion of a particle along a curved path in space is called space curvilinear
motion. The position vector , the velocity , and the acceleration of a particle along a curve
are:(1)
(2)
(3)
Where , and are the coordinates of the particle and , and the unit vectors in the rectangular reference. In the cylindrical
reference (, , ), the description of space motion calls merely for the polar
coordinate expression:(4)
Where,
Also, for acceleration:(5)
Where,
The vector location of a particle may also be described by spherical coordinates as shown in
図 1.(6)
Where,
Using the previous expressions, the acceleration and its components can be
computed:(7)
Where,
The choice of the coordinate system simplifies the measurement and the understanding of the
problem. 図 1. Vector Location of a Particle in Rectangular, Cylindrical and Spherical
Coordinates
Coordinate Transformation
It is frequently necessary to transform vector quantities from a given reference to another.
This transformation may be accomplished with the aid of matrix algebra. The quantities to
transform might be the velocity or acceleration of a particle. It could be its momentum or
merely its position, considering the transformation of a velocity vector when changing from
rectangular to cylindrical coordinates:(8)
or
The change from cylindrical to spherical coordinates is accomplished by a single rotation
of the axes around the -axis. The transfer matrix can be written directly from the previous
equation where the rotation occurs in the
plane:(9)
or
Direct transfer from rectangular to spherical coordinates may be accomplished by combining
式 8 and 式 9:(10)
with:
Reference Axes Transformation
Consider now the curvilinear motion of two particles A and B in space. Study at first the
translation of a reference without rotation. The motion of A is observed from a translating
frame of reference x-y-z moving with the origin B (図 2). The position vector of A relative to B
is:(11)
Where , and are the unit vectors in the moving x-y-z system. As there is no
change of unit vectors in time, the velocity and the acceleration are derived
as:(12)
(13)
The absolute position, velocity and acceleration of are then:(14)
図 2. Vector Location with a Moving Reference
In the case of rotation reference, it is proved that the angular velocity of the reference
axes x-y-z may be represented by the vector:(15)
The time derivatives of the unit vectors , and due to the rotation of reference axes x-y-z about
, can be studied by applying an infinitesimal rotation . You can write:(16)
Attention should be turned to the meaning of the time derivatives of any vector quantity in the rotating system. The derivative of with respect to time as measured in the fixed frame X-Y-Z
is:(17)
With the substitution of 式 16, the terms in the first
parentheses becomes . The terms in the second parentheses represent the components of
time derivatives as measured relative to the moving x-y-z reference axes.
Thus:(18)
This equation establishes the relation between the time derivative of a vector quantity in a
fixed system and the time derivative of the vector as observed in the rotating system.
Consider now the space motion of a particle , as observed both from a rotating system x-y-z and a fixed system
X-Y-Z (図 3). 図 3. Vector Location with a Rotating Reference
The origin of the rotating system coincides with the position of a second reference particle
, and the system has an angular velocity
. Standing for , the time derivative of the vector position gives:(19)
Where, denotes the relative velocity measured in x-y-z, that is:
(21)
Thus, the relative velocity equation becomes:(22)
The relative acceleration equation is the time derivative of 式 22 which gives:(23)
Where, the last term can be obtained from 式 18:(24)
and (25)
Combining 式 23 to 式 25, you obtain upon collection
of terms:(26)
Where, the term constitutes Coriolis acceleration.
Skew and Frame Notations
Two kinds of reference definition are available in Radioss:
Skew Reference
A projection reference to define the local quantities with respect to the global
reference. In fact the origin of skew remains at the initial position during the motion even
though a moving skew is defined. In this case, a simple projection matrix is used to compute
the kinematic quantities in the reference.
Frame Reference
A mobile or fixed reference. The quantities are computed with respect to the origin of the
frame which may be in motion or not depending to the kind of reference frame. For a moving
reference frame, the position and the orientation of the reference vary in time during the
motion. The origin of the frame defined by a node position is tied to the node. 式 22 and 式 26 are used to compute the
accelerations and velocities in the frame.
1Meriam J.L., 「Dynamics」, John Wiley & Sons, Second edition, 1975.
