Nonlinear finite element analyses confront users with many choices. An understanding of the fundamental concepts of
nonlinear finite element analysis is necessary if you do not want to use the finite element program as a black box.
The purpose of this manual is to describe the numerical methods included in Radioss.
Kinematic constraints are boundary conditions that are placed on nodal velocities. They are mutually exclusive for each degree
of freedom (DOF), and there can only be one constraint per DOF.
The stability of solution concerns the evolution of a process subjected to small perturbations. A process is considered
to be stable if small perturbations of initial data result in small changes in the solution. The theory of stability
can be applied to a variety of computational problems.
A large variety of materials is used in the structural components and must be modeled in stress analysis problems.
For any kind of these materials a range of constitutive laws is available to describe by a mathematical approach the
behavior of the material.
Explicit scheme is generally used for time integration in Radioss, in which velocities and displacements are obtained by direct integration of nodal accelerations.
The performance criterion in the computation was always an essential point in the architectural conception of Radioss. At first, the program has been largely optimized for the vectored super-calculators like CRAY. Then, a first parallel
version SMP made possible the exploration of shared memory on processors.
A rigid link imposes the same velocity on all secondary nodes in one or more directions. The
directions are defined to a skew or global frame. 図 1 displays a rigid link. 図 1. Rigid Link Model
The velocity of the group of nodes rigidly linked together is computed using momentum
conservation (Section Definition, 式 1). However, no global moment equilibrium
is respected.(1)
Angular velocity for the ith DOF with respect to the global or a skew reference frame
is:(2)
For non-coincident nodes, no rigid body motion is possible.
A rigid link is equivalent to an infinitely stiff spring TYPE8.
