Measure of Performance
The Speed-Up is the ratio of sequential time T( 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaabm aabaGaaGymaaGaayjkaiaawMcaaaaa@3913@ and the parallel time on P MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOzaaaa@36E1@ processors T ( P ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamivamaabm aabaGaamiuaaGaayjkaiaawMcaaaaa@392D@ :(1)
S ( P ) = T ( 1 ) / T ( P ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4uamaabm aabaGaamiuaaGaayjkaiaawMcaaiabg2da9iaadsfadaqadaqaaiaa igdaaiaawIcacaGLPaaacaGGVaGaamivamaabmaabaGaamiuaaGaay jkaiaawMcaaaaa@4139@
The efficiency is defined as:(2)
E( P )=S( P )/P;E( P )1 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbiqaaWgdcaWGfb WaaeWaaeaacaWGqbaacaGLOaGaayzkaaGaeyypa0Jaam4uamaabmaa baGaamiuaaGaayjkaiaawMcaaiaac+cacaWGqbGaaGjbVlaacUdaca aMe8UaamyramaabmaabaGaamiuaaGaayjkaiaawMcaaiabgsMiJkaa igdaaaa@48CE@
The Amdahl’s law for multitasking is used to determine the speed-up:(3)
S ( P ) = ( T S e q + T P a r ) ( T S e q + T P a r P )
Where, T P a r and T S e q are the computation times respectively related to parallel and non-parallel parts. As T S e q + T P a r = 1 , write:(4)
S ( P ) = 1 ( T S e q + T P a r P )
The limit value can be obtained when the process number tends to infinite:(5)
S ( ) = 1 T S e q
表 1 provides the Speed-Up in function of number of processors and the rate of parallelization in the program. It can be seen that if the rate of parallelization is less 95%, the computation acceleration will not be greater than 20; however, the number of processors. This means that to obtain a good scalability of a code, at least 99% of the program must be parallel.
表 1. Speed-up in Function of Process Number and Parallelization
Process Number
Seq / P
2 4 8 16 32 64 128
100% 2.0 4.0 8.0 16.0 32.0 64.0 128.
99% 2.0 3.9 7.5 13.9 24.4 39.3 56.4 100.
98% 2.0 3.8 7.0 12.3 19.8 28.3 36.2 50.0
97% 1.9 3.7 6.6 11.0 16.5 22.1 26.6 33.3
96% 1.9 3.6 6.3 10.0 14.3 18.2 21.1 25.0
95% 1.9 3.5 5.9 9.1 12.5 15.4 17.4 20.0
90% 1.8 3.0 4.7 6.4 7.8 8.7 9.3 10.0
50% 1.3 1.6 1.8 1.9 1.9 2.0 2.0 2.0
