/ALE/GRID/DISP
Engine Keyword With this keyword it is possible to modify grid formulation parameters, which initially was set in Starter keyword /ALE/GRID/DISP. (Altair average displacement grid formulation).
/ALE/GRID/DISP
Umax Vmin
Umax | Maximum absolute grid
velocity. (Real) |
Vmin | Elements with a volume
less than Vmin will
be deleted. (Real) |
- For more details, refer to ALE Grid Calculation in the User Guide and /ALE/GRID/DISP in the Starter Reference Guide.
- Default values are taken from a previous run.
