/ALE/GRID/STANDARD
Engine Keyword With this keyword it is possible to modify grid formulation parameters, which initially were set in Starter keyword /ALE/GRID/STANDARD. (Altair standard method for grid velocity computation).
/ALE/GRID/STANDARD
α lc
| α | Scale factor on maximum
stiffness. (Real) |
| Nonlinearity factor for
edge spring stiffness. (Real) |
| Damping
coefficient. (Real) |
| lc | Characteristic
length. (Real) |
- Default values are taken from a previous run.
- As of v12.0.210, /ALE/4 was replaced by /ALE/GRID/STANDARD.
- Mesh auto correction can be
introduced by giving more weight to anti-shear forces by either:
- Setting parameter close to the mesh size.
- Setting a negative value for α parameter (elastic forces on edges are set to 0 at the first cycle of current run).
