/ANIM/VERS
Engine Keyword Generates animation files in Radioss environment post-processing formats 41 and 44.
/ANIM/VERS/Version Number
Version Number |
- If the deck includes SPH,
/ANIM/VERS/44 should be used.
- The size of the animation files will be smaller
- The displaying of SPH particles is best
