/VERS
Engine Keyword Identifies the input data version number.
/VERS/Version Number
Version Number Radioss Input Manual Version 110
  1. This keyword is compulsory.
  2. This option represents the input format version for Radioss Engine.
  3. The number version must be coherent with the number version in Radioss Starter.
  4. The Radioss Engine and Starter Input files must have an extension corresponding to the format used (refer to the Starter Input manual).
