/BCS/TRA
Engine Keyword Given node numbers will be constrained in specified directions X, Y or Z for material translational DOF: V = 0.
/BCS/TRA/Keyword3/skew_ID
N1 N2 ..., NN
Keyword3 | Any combination of
X, Y, and
Z: X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, ... |
skew_ID | If omitted, the boundary conditions are applied in the global skew system; otherwise they are applied in the given skew_ID. | |
N1, N2 . . ., NN | List of node numbers to which the boundary condition will be applied. |
