/VEL/TRA
Engine Keyword Given node numbers have the same velocity in a specified direction X, Y or Z for material translational DOF.
/VEL/TRA/Keyword3/skew_ID
N1 N2... NN
Keyword3 A combination of X, v, and Z:
X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, ...
skew_ID Skew identifier (optional).
If omitted, the equation is written in the global skew system; otherwise it is applied in the given skew_ID.
N1 N2 ... NN List of node numbers having the same velocity.
  1. Given node numbers have the same velocity in a specified direction X, Y or Z for material translational DOF (Rigid links):(1)
    V X = j = 1 N M J V x j j = 1 N M J
