/DEL
Engine Keyword Delete element numbers N1, N2, . . ., NN.
/DEL/Eltyp
N1, N2 . . ., NN
NN+1, NN+2 ..., NM
Eltyp | Element type:
N1, N2, . . ., NN | List of element
numbers. Maximum 100 characters per line. |
- The element numbers can be listed in multiple lines with a maximum of 100 characters per line.
- The element numbers can be separated by a comma or space.
- Elements with void material cannot be deleted.
