/FUNCT
Engine Keyword Redefines the fct_ID initially defined in the Radioss Starter Input. The same number of points should be given.
/FUNCT
fct_ID
X1 Y1
X2 Y2
XN YN
fct_ID Function identifier.
X1 X2 . . . XN Abscissa value.
Y1 Y2. . . YN Ordinate value.
