/DT/SHNOD/Keyword3
Engine Keyword Time step control for shell sub-cycling.
/DT/SHNOD/Keyword3
Keyword3 | Time step control
type.
If Keyword3 is not specified, that is, /DT/SHNOD, then the shell elements will use the nodal time step method and is not used. |
Scale factor on nodal
stability time step for shells. Default = 0.9 |
Minimum time step. |
- Shell sub-cycling is activated by using the Engine file option, /SHSUB.
- /DT/SHNOD/CST can be set in the Radioss Engine file, to use an imposed nodal time step
for SHELL and SH3N elements sub-cycling.
Just like /DT/NODA/CST, mass will be added to maintain
(1) is lower than - /DT/SHNOD sets a different time step for all shells (SHELL and SH3N) and shells only. Time step parameters of the rest of the model are defined in /DT/NODA. /DT/NODA is required, if /DT/SHNOD is used.
