/H3D/COMPRESS
Engine Keyword Compress the H3D file.
/H3D/COMPRESS
Max%Loss
Max%Loss | Maximum percentage change in results, suggested value = 0.001. |
- Maximum percentage loss indicates the
allowable amount a model’s values can change when compressed.
The value provided will be compared to the results of an error estimation function to allow the compression algorithm to maintain an acceptable level of accuracy for your data.
However, even a percentage of zero may result in some loss due to minute rounding errors.
