/H3D/LSENSOR
Engine Keyword Write additional animation time steps to the H3D file when a sensor in the list is activated.
/H3D/LSENSOR
sens_ID1 | sens_ID2 | sens_DN |
sens_ID1, sens_ID2, sens_IDN | List of sensor ID's |
- The animation data written, due to the sensor activation, is in addition to the time step output, defined by /H3D/DT.
- The animation data is written each time a sensor in the list is activated. For more explanation about sensor activation, refer to /SENSOR.
