/IMPL/DYNA/2
Engine Keyword Describes the implicit dynamics with a general Newmark method.
/IMPL/DYNA/2
γ β
γ Implicit dynamic with general Newmark method.
(-2 β γ ≤ 1/2) γ , β =0 set to γ =1/2; β =1/4.
β Implicit dynamic with general Newmark method.
  1. The nonlinear parameters, rather than default values can be defined in /IMPL/NONLIN.
  2. An α-HHT method is the default implicit dynamic method, if /2 is omitted.
