/IMPL/RREF/LIMIT
Engine Keyword Define reference force residual limit values used in stop criteria for implicit nonlinear.
/IMPL/RREF/LIMIT
R_min R_max
  1. Directly defining the reference force residual limits allows to ensure the precision (with R_max) or to make convergence easier (R_min).
R_min Minimum force residual value.
Default = 0 (Real)
R_max Maximum force residual value.
Default = 0 set to 1.e30 (Real)
