/MADYMO
Engine Keyword Activates MADYMO- Radioss coupling.
/MADYMO/Keyword2
lunit tunit munit
| Keyword2 |
| lunit | Length unit conversion factor, must be 1 meter in Radioss model unit. | |
| tunit | Time unit conversion factor, must be 1 second in Radioss model unit. | |
| munit | Mass unit conversion factor, must be 1 kg in Radioss model unit. |
- /MADYMO/MPP requires MADYMO 7.1 or higher installation.
- If using Radioss- MADYMO coupling, /MADYMO/MPP must be input into every Engine file (Runname_run#.rad).
- Units settings: For example, if Radioss model units are mm, s, or kg, the factors will be 1000, 1, 1, respectively.
- MADYMO is a registered trademark of TASS-SAFE.
