/RERUN
Engine Keyword Permits to continue a previous Radioss run.
/RERUN/Run Name/Run Number
Run Name Character variable that identifies the problem solved.
(Character, minimum 4; maximum 80 characters)
Run Number 1, 2, . . .
  1. The Run Number is the same as the previous Radioss run.
  2. In the case of a control file, a "CHECK_DATA" file is automatically created by Radioss Engine with this option by using /CHKPT in Control File (C-File) Runname_run#.ctl. This file can be used to restart the computation as an input file for Radioss Engine instead of runname_run#.rad.
  3. It is also possible to put such an option inside a CHECK_DATA file you created.
