/SUBDOMAIN
Multi-Domain Keyword Defines the parts belonging to the subdomain of a Multi-Domain computation.
/SUBDOMAIN/subdomain_ID | |||||||||
subdomain_title | |||||||||
Part1 | Part2 | Part3 | Part4 | Part5 | Part6 | Part7 | Part8 | Part9 | Part10 |
subdomain_ID | Subdomain
subdomain_title | Subdomain
title. (Character, maximum 100 characters) |
Part1, Part2, ... Partn | List of
parts (Integer) |
- Currently only one domain can be defined.
- The subdomain title is used as the rootname for the new Radioss model created for the subdomain.
- These options are not
compatible with /SUBDOMAIN:
- /DFS/DETPOINT/NODE
- /FX_BODY
- /SPHBCS
- For more information concerning Multi-Domains, refer to Multi-Domain Technique.
