/UPWM/SUPG (Obsolete)
Engine Keyword This describes the Streamline Upwind Petrov Galerkin formulation.
/UPWM/SUPG
fac
fac | Scale factor applied on
Petrov Galerkine weighting function. Default = 1.00 (recommended value). |
- The streamline upwind Petrov-Galerkine (SUPG) is an optimal upwinding technique which acts only in the flow direction.
- If this keyword is used, the usual upwind method for momentum advection is no longer used. As a consequence, the coefficient from /UPWIND (Obsolete) Starter is also not used.
- The Galerkin (shape function φ)
are modified to integrate the momentum convection term [(u -
w). ∇]u, which leads to a Petrov Galerkin method using
weight function W* such as:
(1) Where, k' is a function of the Reynolds number, material velocity and element length, and fac is a scale factor. fac = 1.00 is the standard value for SUPG formulation (recommended).
- /UPWM/SUPG is activated by default in 2D and 3D analysis, as it returns the most accurate results.
- It is available for multi-material LAW51.
- The upwinding technique is
introduced to add numerical diffusion to the scheme which, otherwise is
generally under-diffusive and thus unstable. The usual method is first: order
accurate and strongly depends on the mesh aspect. In some cases (see examples
below) the classical method might lead to locally erratic velocities with
unsuitable meshes. SUPG method provides more accurate results, if the phenomenon
is sensitive to mesh aspect. It is recommended to systematically activate
it.Modeling situation: A regular mesh is used although this phenomenon has spherical evolution. Result are obtained with multi-material LAW51.Velocity Result - Classical UPWIND: Classical UPWIND method for momentum transportation is not suitable with spherical evolution and regular mesh.Velocity Result - SUPG: SUPG method for momentum advection removes mesh sensitivity. It is no longer required to have a spherical mesh to model spherical phenomena.
