/UPWM/TG (Obsolete)
Engine Keyword Describes the Taylor Galerkin method for momentum advection. This method is not available with multi-material LAW51 (/MAT/MULTIMAT).
/UPWM/TG
fac
fac | Coefficient for upwind
term. 3 Default = 1.00 |
- A Taylor development is applied on velocity vector and substituted in Navier Stokes equations. Integration is performed using standard Bubnov Galerkin integration. This introduces terms with a streamline character. Assumption is made that viscous stress is negligible (high Reynolds number). This is also not valid for stationary cases.
- If this keyword is used, the usual upwind method for momentum advection (defined with coefficient from /UPWIND (Obsolete)) is replaced.
- Best results are obtained
for:
(1) Where, M is the Mach number. Which means for subsonic simulation, coefficient fac > 1 is advised. The original TG method is obtained for fac = 1.00 and does not take into account compressibility for stability time step (upwind term is proportional to it).
- The /SUPG and /TG options are available in 3D Euler, 3D ALE and 2D Euler, although they are not recommended in axisymmetric cases.
