Animate and Record Results
If you've previously run a 3D printing analysis, use the Animation toolbar to animate and record the results.
Result Types for Binder Sinter
3D printing analysis for Binder Sintering produces results for Displacement, Sinter Deviation, Relative Density, Temperature, and Volume Change.
