Motion Contact Force Results Not Found
Condition
Loads coming from motion contacts are missing. If you click the Continue button, the missing loads will not be applied to the part.
Cause 1
The Keep Force Results option was set to None in the Run Motion Analysis window.
Remedy
Cause 2
While the Keep Force Results option was set to All or Region Only in the Run Motion Analysis window, this setting was overridden in the Property Editor for one or more motion contacts.
