Use the Center of Gravity Constraint (COG) tool to apply, reposition, and set upper and lower bounds for a center
of gravity constraint. COG constraints are used to limit the position of the center of gravity while running a topology
optimization.
Apply loads and supports, displacements, accelerations, gravity, temperatures, and
center of gravity.
Loads and Supports
Use the Loads tools on the Structure ribbon to apply forces, pressures, torques, and supports to your model.
Displacements
Use the Disps tools on the Structure ribbon to apply enforced displacements and displacement constraints.
Accelerations
Use the Accels tools on the Structure ribbon to apply g-Loads and angular velocity/acceleration.
Gravity
Use the Gravity tool to apply gravitational acceleration (G) and adjust its direction.
Temperatures
Use the Temperature tool to simulate the effects of temperature changes on your model.
Center of Gravity (COG)
Use the Center of Gravity Constraint (COG) tool to apply, reposition, and set upper and lower bounds for a center of gravity constraint. COG constraints are used to limit the position of the center of gravity while running a topology optimization.
