An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses.
Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses. Geometric variables may be sketch dimensions, lengths, angles, or push/pulls. Geometric constraints are minimum and maximum values for
the defined variables. These constraints are specified in the Design Variable tab and the variable's value
will vary within the exploration.
Objectives are metrics to be minimized or maximized in an optimization exploration. Common examples are minimizing
displacement to find the stiffest design for a system or minimizing mass to find a lightweight design.
Objectives
Objectives are metrics to be minimized or maximized in an optimization exploration. Common examples are minimizing displacement to find the stiffest design for a system or minimizing mass to find a lightweight design.
Constraints
Constraints can be added to an optimization and need to be satisfied for a feasible exploration.
