Constraints
Constraints can be added to an optimization and need to be satisfied for a feasible exploration.
Create Constraints
Constraints can be added to an optimization and need to be satisified for a feasible design.
Constraints can only be applied to an Optimization exploration.
Method | Steps | Notes |
(A) Use the microdialog of an existing response |
(B) Use the Goals tab in the Design Explorer |
To rename the constraint, double-click the corresponding
Name field. To apply/unapply a constraint to the Active Exploration, turn on/off the corresponding Active check box. |
