JSON
The JSON connector allows the retrieval and processing of JSON files, either from a disk, a Text, or from a defined URL.
1. Select JSON from the Data Sources pane. The JSON Settings pane and the retrieved JSON source are displayed.
2. Enter the Name of the JSON data source, then click
3. Select the JSON File Source.
4. Click to the fetch the schema based on the connection
details. Consequently, the list of columns with the data type found
from inspecting the first ‘n’ rows of the input data source is populated
and the Save button is enabled.
5. You can also opt to load or save a copy of the column definition.
6. Click
to add columns and specify their properties:
Property |
Description |
Name |
The column name of the source schema. |
Json Path |
The Json Path of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message field should be processed. |
To delete a column,
check its or
all the column entries, check the topmost
, then click
7. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
8. Set the row limit of the data set.
9. Tap the Preview Selected Data Source slider to turn it on.
10. Click to display the data preview.
