Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming. These tools
allow for more control over surfaces.
Export selected objects to a common folder used to exchange data with other Altair products. For example, you can export a die design from Inspire Studio to Inspire Form to perform a stamping simulation.
Create a draw die in Inspire Studio that you can export to Inspire Form to perform a stamping simulation.
Change the User Profile
Customize the tools available in the product. Choose from Full, Studio, Render, and Stamping Die Design.
Configure the View
The following custom die design camera views are available: top, front, or right.
Part
First define the part and then adjust the draw direction to create a draw die.
Binder
Define one or more binders for the draw die. You can either assign an existing surface as a binder or create a flat from a new surface.
Addendum Loft
Addendum Extend
Create one or more surfaces that extend from the part to the binder, to aid in stretching and forming. These tools allow for more control over surfaces.
Die
Trim the binder and add a round to finalize the draw die. Create a matching die by offset.
Drawbead
Define a bead line and create a drawbead from it.
Export to Exchange
