The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
When an instance of is added, any users who were added to AM via
the command line are pulled into Control.
Choose one of the following options:
Click the Monitor tab.
Click the Configure tab.
Choose one of the sub-menus listed under the Allocation Manager
menu located on the left-hand side of the web page.
Click Manage Instances.
A dialog box appears where information about the Budget Manager instance is entered.
Figure 1. Manage Instances
For Instance Name, enter the name of the Budget Manager instance as it will appear in the
Control web application.
The instance name must be 20 characters or less.
For Host, enter the hostname of the machine where
Budget Manager is installed by entering its:
IP address - a four-part number string such as 18.72.0.3.
Host name - a text string such as hpc.altair.com.
If Budget Manager is listening on a non-default
port, click Show advanced options.
Default port is 8000.
For AM Port, enter the port that Budget Manager listens on.
Click Add.
The instance of Budget Manager is now
accessible by the user who added it and any users who are Managers. The
following notification is displayed to the user adding the instance or any
Managers that are currently logged into Control:
Your view is updated to reflect the privilege changes in cluster: INSTANCE
where
INSTANCE is the name of the Allocation Manager instance.
Troubleshooting: The below error indicates that the instance has already been
added by another user (either an AM Admin or a Manager).
While performing aminstance action: Unable to add Budget Manager instance at INSTANCE
where INSTANCE is the name of the Budget Manager
instance.
To resolve this issue, a Manager must grant access to the
instance.
Use the Configure tab to
configure the instance. Use the Monitor tab to monitor the
instance.
