The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Delete an Budget Manager instance that you no longer
want to configure or monitor.
Instances of Budget Manager can be deleted by:
users assigned to the Manager role.
any user who is assigned to an AM Admin role that has been granted access to the
instance by a Manager or who added the instance of Budget Manager.
AM users that were pulled into Control when the instance was added
are not removed from Control.
Choose one of the following options:
Click the Monitor tab.
Click the Configure tab.
Choose one of the sub-menus listed under the Allocation Manager
menu located on the left-hand side of the web page.
Click Manage Instances.
Budget Manager instances that have been
previously added are listed on the left hand side of the dialog box.
Figure 1. Budget Manager Instances
Click
next to the name of the instance that you want to delete.
Click Remove.
The instance is removed. Any users who had access to the instance no
longer have access to it. The following notification is displayed to any
currently logged in users that had access to the Budget Manager instance:
Your view is updated to reflect the privilege changes in cluster: INSTANCE
where
INSTANCE is the name of the Allocation Manager instance.
