The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Revoke Access to a User Managed Instance of Budget Manager
Managers can revoke access to an instance of Budget Manager that has been added
by an AM Admin.
Budget Manager administrators can add instances of Budget Manager so that the instance can be configured and monitored through Control. A Manager can revoke this access to the instance.
Once the
access to the instance is revoked, the user cannot re-add the instance. If the user
attempts to re-add the instance, the following message is displayed:
While performing aminstance action: Unable to add Budget Manager instance at <instance name>
Click the Configure tab.
Click Users from
the Access Management menu located on the left-hand side of
the web page.
Click the name of the user.
Figure 1. Select User
Click Edit.
Click to revoke access to the cluster.
Figure 2. Revoke Access to an Instance of Budget Manager
Access to the instance is revoked for the user. The following
notification is displayed to the user if the user is currently logged into
Control:
Your view is updated to reflect the privilege changes in cluster: INSTANCE
where
INSTANCE is the name of the Allocation Manager instance.
