Modifying the Quantities of a Far Field Result Trace
Change the far field trace axis to dB.
myFarFieldTrace.Quantity.ValuesScaledToDB = true
Figure 1. The quantity panel in the result palette.
  1. Search for the FarFieldQuantity object in the Help1.
  2. In the Help under FarFieldQuantity > Property List, search for a property applicable to changing the trace values to dB:
    • ValuesScaledToDB
  3. In the Help, under FarFieldQuantity > Usage locations, note the following:
    FarFieldTrace object has property Quantity.
    The result is then:
  4. Since we already has a handle on the far field trace, the result is:
Feko Scripting and API Reference Guide
1
The API is available in the (PDF) or Feko WebHelp.
