Creating a Cable Port
Apply a cable port to a cable harness.
- Open the cable schematic view for the cable harness of interest.
                On the Source/Load tab, in the
                            Ports group, click the
 Cable Port icon.
                The cable port symbol is added to the active cable schematic view. - Connect the port to other schematic elements.
                From the right-click context menu, select Properties to
                    change the label for the cable port.
                The Modify Cable Port dialog is displayed.
Figure 1. The Modify Cable Port dialog. - In the Label field, add a unique label for the cable port.
 - Click OK to apply the new label and to close the dialog.
