Post Processing
Use SnRD Post Processing tab to load and process the results.
The post-processing operation requires the model used for analyzing the squeak and
rattle phenomena. Post-processing will require the solver deck
(.FEM
) exported from the pre-processing module. This solver
deck is used throughout post-processing for creation of contour plots.
Post Processing Options
Description of Post Processing options.
- Model File
- Select the OptiStruct solver file (.fem) exported from Export OptiStruct Solver File.
- Pre-Output File
- Select the pre output CSV file.
- Results File(s)
- : Select and add a results file for post processing.
- Subcase Selection
- All subcases in the selected results file are listed in the table.
- Save Session File
- Name the session file and select a destination folder.
- Post Processing
- Analysis Type
- Rattle & Squeak
- Analyze all the lines in the model.
- Rattle
- Analyze only the rattle lines.
- Squeak
- Analyze only the squeak lines.
- Lines to analyze
- Select All or only the required E-Line to analyze.
- % statistical evaluation
- Specify the percentage of statistical evaluation based on the methodology implemented for studying the squeak and rattle analysis.
- Session Type
- Summary
- Creates one session per subcase with only the overview pages for each of the squeak and rattle interface in the model.
- Full Analysis
- Creates one session per subcase, along with detailed plots for each of the interfaces present in the model.
