Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
In the PEM Portal homepage, you can select which material pairs to include in investigation either by creating a new
search or selecting a previously saved search.
The Results Page provides an overview of the compatibility of the selected material pairs. Use the Results Page to
identify which material pair have a high risk of squeak and which do not.
pairs. Use the Results Page to identify which material pair have a high risk of squeak and
which do not.
The following colors are assigned to each material pair:
Green: Low risk of Squeak.
Red: High risk of Squeak.
Medium: Relatively lower risk than Red.
From the Results page, you can review details of material pair, refine results,
set a Material Pair as favorite, save search, and compare results.
Review Details of Material Pair
Click on individual material pair card to view more details.
Set a Material Pair as Favorite
Click the star icon in the material pair card to mark it as a favorite. Favorite
material pairs will be listed in the PEM Portal homepage.
Save Search
Click Save Search.
Enter a title for the search and click Save.
Saved searches are accessible from PEM Portal home page. Each PEM
session is bound to your machine MAC ID and will be saved in
session.
Compare Results
Compare enables you to select material pair cards for comparison. You can compare up
to four material pairs.
Click Compare to select materials. Click Compare
Results. This launches the comparison chart containing parameters
for the selected pairs.
