Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
From the HyperGraph menu, select Radar
Chart to display the Radar Chart ribbon.
You can use HyperGraph to plot vector, phase vs.
magnitude, and radar plots. Use radar plots to plot complex data. The phase axis for
a radar plot is equivalent to the phase axis for a complex plot. The mag-axis for a
polar plot is equivalent to the magnitude axis for a complex plot. The key
differences are plotted polar coordinates - only a single frequency is
displayed.
Figure 1. Radar Chart Ribbon
Define
Edit existing curves and add new curves to the current plot.
Datums
Add horizontal and vertical datum lines to plots.
