Mount Optimization - Display Tab
Review rigid body mode frequencies and corresponding kinetic energy distribution. Right-click on the context menu to display and visualize rigid body modes.
Figure 1. Mount Optimization Utility - Display Tab
View new features for HyperWorks 2022.1.
The Aerospace menu provides you with access to various aerospace tools.
The NVH menu provides you with access to various NVH utilities.
Allows you to plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
The Model Correlation utility determines the degree of similarity or correlation between two sets of results.
Predicts powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
Enter the powertrain and mounting configuration data manually or load the data from a configuration file. Mount stiffness can be static or non-linear.
Plots mount displacements and reaction forces in various static, dynamic, and transient loading conditions, which aids in understanding the mount's load carrying capacity and the mount's interference with vehicle structure. Optionally, you can add custom static loadcases.
Plots the Torque Roll Axis with respected to the crankshaft axis direction.
Perform sensitivity studies for mount position and stiffness. You can also perform an optimization setup to calculate the optimized mount stiffness and location layout for decoupling powertrain rigid body modes and frequency spacing.
Use the Safety ribbon to access crash and safety post-processing tools.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
