View new features for HyperWorks 2022.1.
Query and view key information about selected entities live when in idle mode.
Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
When exporting results from an advanced query to an HTML file, HyperView creates a separate H3D file for every red or blue cell in the last column of the table.
The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
Use the Plots tool to construct multiple curves and plots from a single result file.
Starting in version 2021, the Stress Linearization tool has been renamed as Extract-Linearize and will support both the Extract Data and Stress Linearization methods.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities based on selection set, threshold values, minimum separation, and load cases. In addition, you can plot the search results with annotations and selective amount of details displayed on screen.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
ON THIS PAGE
See the Exporting Advanced Query Data to an HTML File topic for additional information.
ON THIS PAGE
