Perform a Hotspot Search with Default Criteria
Perform a basic hotspot search with the default criteria calculated in the current simulation and subcase.
View new features for HyperWorks 2022.1.
Query and view key information about selected entities live when in idle mode.
Use the Query tool to view and export properties and other information for nodes, elements, components, and systems contained in the active model.
The Free Body Diagram (FBD) tool facilitates the extraction and post-processing of Grid Point Force (GPFORCE) results and can be used create and edit Free Body Diagrams (FBD).
Use the Plots tool to construct multiple curves and plots from a single result file.
Starting in version 2021, the Stress Linearization tool has been renamed as Extract-Linearize and will support both the Extract Data and Stress Linearization methods.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities based on selection set, threshold values, minimum separation, and load cases. In addition, you can plot the search results with annotations and selective amount of details displayed on screen.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
 to perform a search. The hotspots will be shown
                    with notes in modeling area attached to the hotspots.
                Default search criteria searches for the hotspots through all of the displayed entities, with a threshold for more than 80% of the legend max value, separation between hotspots as 10% of the length of the biggest diagonal in the model bounding box, and filtering out the top five values.
