Browsers supply a great deal of view-related functionality by listing the parts of a model in a tabular and/or tree-based
format, and providing controls inside the table that allow you to alter the display of model parts.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Create and edit user-defined data type expressions, derived load cases, and systems. You can also plot a forming limit
diagram, generate streamlines, track entities during animation, and create and import/export sets of entities.
Query entities, create or edit free body diagrams, construct multiple curves and plots from a single result file, and
create and plot stress linearization.
Contour time of failure or failure status of elements.
Failure Time is a special scalar result type that is created by HyperView based on Erosion (failed elements) data available in the
result file. No extra step is required; if the results contains Erosion, then a data type
called FailureTime is automatically created.
Attention: This is available in the HyperWorksHyperView – Upfront Loader profile only.
Three result components are available for contouring under the FailureTime result type:
Value
Contour plot will show the time at which an element fails.
Frame
Contour plot will show the animation frame number at which an element fails.
Status
Contour plot will show whether an element fails or not during the simulation.
Figure 3.
Note: The FailureTime contour plot is based on the steps that have
been loaded. For example, assume that a simulation has 50 steps, and no element fails in
the first 10 steps. If only the first 10 steps are loaded and FailureTime is contoured,
then the plot would show N/A. Therefore, it is recommended that all the steps of the
simulation be loaded before loading FailureTime in order to display precise failure
information on an element.
